Intermediate Mariner
Hopefully some of you have probably seen this before or know about it.
In performing a variety of repairs I have removed powerhead and cylinder head. I had the PH on the bench with the top of the pistons exposed and noticed that the pistons are pretty darn loose!
I mean I know there should be SOME clearance between the rings and cylinder wall (the book shows 0.005) but geeze, I can wiggle them good! This is my first outboard overhaul but I remember automotive pistons being in there pretty tight and having no wiggle room at all!
Should the pistons be in there tight and immoveable? Or am I in for ring replacement (and if so, should I replace bearings if they look good or just rings and go)? Also, will I need ring compressor or can I install by hand?
PS: Motor IS NOT locked up and feels pretty smooth and turns easy, maybe too easy... I can grab the top of crankshaft with my hand and turn it effortlessly, should it be that easy to turn?
Thanks a Million!
Shawn
