Ready to run up the white flag. Motor acts like it wants to start, but will only occasionally backfire. New coils (green), points, condensers, plug wires, and plugs. Points gapped at 0.020. Spun the engine with plugs out and both are getting spark. Cleaned and rebuilt carb and new fuel pump diaphragm. Good fuel flow to float bowl, primer bulb nice and firm. New head gasket, bolts torqued to 15 ft/lbs. New impeller and seals. Replaced leaking power head base gasket and the inner exhaust housing was loose. Tightened it up with a new gasket and lower seal as the old ones were trashed. Any ideas on what could be the problem?
