kazann9847
| I have a 1960 17' Tollycraft Sportabout with a Ford 215 HP interceptor inboard engine. I ran the engine with the boat out of the water supplying water to the water intake at boat bottom and did not get any water being exhausted while engine running. I turned off the engine to prevent overheating shortly. I am not that knowledgeable on the water cooling system. Does the inlet water circulate through the engine after engine warms up or should it be immediate and water exit through the exhaust ports? How can I troubleshoot further? What would be a source for parts if any is needed? Thank you, Kaz |
