"I have this old motor (mo
"I have this old motor (model # V4 S 12). I have recently had problems with the motor/propeller locking up. I disassembled the gearcaseallthe way up to the forward gear. The propeller shaft is supposed to slide out from there but it will not come out. I suspect the bearing cone has been heated up and ruined, and for what ever reason causing the the shaft to not slide out. Anyone know of any way to remove the propeller shaft so I can remove the forward gear and remaining components? Thanks for your help in advance."
