I need some help with a 1960 Evinrude 5.5 hp Fisherman outboard motor. I don't know it's history but it looks good. It is hard to start and will only start if the throttle is wide open and then it runs a little above idle speed. The rpms eventually get up to about 3/4 of what it should be. It will die if the throttle is over half closed. Adjusting the mixture screws doesn't seem to do anything. I've cleaned out the carburetor, and the filter but it didn't make any difference. The air intakes are clear. squeezing the fuel priming bulb makes no difference. The low screw is set to 1.5 turns out and the high screw is at 3/4 turns out per the manual. The original spark plugs looked good so they are still in. after running it the plugs look oily. There is a lot of oil in the water tank afterward. I feel like it is running rich. Any ideas on what to look at next?
