1959 evinrude 55 fuel problems
dougsamual
It has a pressure tank and I w
It has a pressure tank and I wanted to know if there is a rebuild kit for the tank or if it can be converted to a fuel pump?
"Parts to repair the pressure
"Parts to repair the pressure tank are also available here. Diaphragm is part # 305715 (if the tank is from 58 or newer) and the gasket for the tank is part # 302557. The diaphragm for 51-57 is part # 377327. Check the pictures at http://www.nymarine.ca/fueltankparts.htm to tell the difference if you are not sure which you have."
"thnx and welcome back [img][/
