First post in this forum. Thank you ahead of time to the helpful and knowledgeable folks helping others. Also thanks to the administrators for your work.
My old 1959 Johnson 18 HP has been very reliable for 35 years for my small fishing boat. It has sat for a dozen years but started right up for me, however ran a bit rough. I could not adjust to run well so I tackled a few things. New carb kit, plugs and an in-line fuel filter. Also cleaned the gas tank thoroughly as well as all fuel lines. I meticulously cleaned every part of the carb when apart.
With that said, I took to the lake for a trial run. It started right up but when I tried to run at high speed it was cutting out. The high speed adjustment would not correct the problem. When I did the carb rebuild I started with: Hi Speed backed out 1 turn, Low speed 1 1/2 turns. It idles and trolls fine. I did not bring the proper tools to the lake to macro adjust the high speed needle valve so I brought it home. Ironically there were no leaks or other problems until today when I hooked up the gas line and pressurized it. Fuel is coming out of the throttle body intake throat (where the choke flap is) now. I am assuming I have a stuck float in the carb. Before I tear into it again I wanted input on what else might be going on here. I may just put the old float back in as it worked fine. No leaks from fuel lines or anywhere else, just coming out the carb intake. Input welcome. Thanks
Spokane, WA
Spokane, WA
