1958 JOhnson 50 hp v-4 electric start
h@nnaha12
would you please share your thoughts on
what is fair price range to offer for purchase of:
1958 Johnson v -4 50 hp electric start
restores several years ago
motor has been run several years ago
good condition
These motors were the ----Ultimate gas hog ---------------If you need a daily runner than look for something newer.----------If you want to own a first year V-4 motor to display on your wooden boat and to run it once a year than go for it.--------------Pay about $300.00 for a runner.
If you get the timing pretty close to being exact, and have the carburetor adjusted perfectly, the gas consumption isn't too awfully bad UNLESS you operate at full throttle constantly. Carburetor adjustment procedure follows.
(Carburetor Adjustments - Older V/4 Downdraft Carb)
(J. Reeves)
NOTE: The early model downdraft carburetors incorporated "Adjustable High Speed Jets". The later model downdraft carburetors used "Fixed High Speed Jets". Follow the below instructions accordingly.
NOTE: If you do not have adjustable high speed jets, ignore those paragraphs pertaining to same...... BUT do make sure that you manually inspect and clean the two brass fixed high speed jets which would be located in back of the two 7/16" slotted hex head bolts in the bottom front portion of the float chamber.
Lift the center High Speed Control lever and turn it so that the point faces forward, resting on the high ridge. This will disengage the lever control gear from the individual high speed jets (slots). Have the slow speed needle valve knobs installed upside down so that they can be turned without encountering any obstruction.
Gently seat each of the High Speed needle valves, then back each one out one (1) turn. Gently seat each of the Slow Speed needle valves, then back each one out one and one half (1-1/2) turns. NOTE... have the jam nut on the s/speed needles snug so that vibration won't have any effect on them, but loose enough so that you can turn them without a great amount of effort.
(High Speed)
With a reliable person at the wheel, and one kneeling in front of the engine, start the engine (yes, it will run lousy with the above initial needle valve settings), put it into forward gear, and apply full throttle. Start with the High Speed adjustment on the left using a screwdriver that properly fits the slot.
(High Speed Adjustments)
At full throttle, with the proper size screwdriver, slowly start turning one of the H/S needles in segments of 1/8 turn, waiting momentarily for the engine to respond, then repeat turning. You will reach a point where the engine will start to die out. At that point, back that needle valve out approximately 1/4 turn. Now, go to the other High Speed needle valve and repeat that procedure. At some point in that 1/4 turn out, you will find the smoothest high speed setting (you can now lower the throttle rpm). That will have both high speed needle valves set correctly, and at that point you can lift that center lever adjustment of that high ridge, keeping it lifted until the point is facing the engine, then lower it into its proper position. (When you turn that lever now, you're adjusting both High Speed needle valves at the same time.)
(Slow Speed Adjustments)
Now, lowering the rpms of course, take the engine out of gear and set the throttle just to where the engine will stay running. Again, in segments of 1/8 turn, slowly start turning in one of the slow speed needle valves, waiting a few seconds between each turning for the engine to respond. As you turn the s/speed needles in, the rpms will increase..... and as it does, lower the rpms to where the engine will just stay running (otherwise the rpms will climb quite high). You will reach a point whereas the engine will either start to die out or it will spit back (sounds like a mild backfire). At that point, back the needle valve out 1/4 turn. Repeat the process with the remaining slow speed needle. Again, at some point in that 1/4 turn out, you will find the smoothest setting. When finished, tighten the jam nut somewhat, then remove and reinstall the s/speed knobs correctly (right side up).
thanks and what would you think would be acceptable price range to purchase one of these, restored and running, good condition (not excellent)
No idea.... my line of expertise was with repairs and the cost of repairs. The worth of any engine really is like beauty, it's in the eye of the beholder BUT I would say not to exceed Racerone's quote. What is the fellow asking for it? Possibly he just wants to get rid of it.
that good...a perfect response...."...they're coming to get you haha, hehe, they're coming to take you..." I can hear that tune...crap...it will most likley be playing all day in my brain...thanks! :)
