1958 Johnson 5.5 hp (cd-cdl-15) parts question.
DanaFoley357
I have a 1958 Johnson 5.5 hp outboard. The water pump housing needs to be replaced. I'm told the part is not available. Any suggestions ? Thanks in advance for the help.
You can get an entire water pump repair kit that will have the housing inside. The part number is 763758 which supersedes kit 391391.
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0763758&ptype=&Engine=&Model=
I should point out that the impeller in this new kit is different from the original design. It uses a smaller (around 1.5" diameter) impeller as opposed to the original 2.5" one. The benefit here is that the impeller should pump water a little stronger and wear out slower.
If you still want just the housing then you can find it here.
http://www.marineengine.com/newparts/part_details.php?pnum=OMC0303442&ptype=&Engine=&Model=
Unfortuneately the housing is more expensive then the entire kit. I use this kit on my 1961 5.5Hp Johnson and it works great.
Thats very helpful. Thank you very much
