1958 johnson 10hp running rough
bob_s
Hey- was hoping to get some he
Hey- was hoping to get some help. my motor runs pretty well but at top speed and when the motor heats up it starts to jerk every now and then almost like i hit a log (I didn't). Any suggestions?}}
"ck the brass conn for shifter
"ck the brass conn for shifter rod...however....very common,to be worn clutchdog,and forward gear..."
"u might also,..ck the spark,w
"u might also,..ck the spark,when it does this,as 'heating up' is not,..'gear' specific,meaning,..if cdog and fgear were bad,..it would do it any time,u nailed it.."
thanks for the advice. Also I
thanks for the advice. Also I have been told it could be the impeller. What are your thoughts?
"well,..if it has not been rep
"well,..if it has not been repl.....repl it!...but,bad imp,is not gonna cause 'jerking'...slowing down steadily,as it overheats,..is the norm.......then,u r doing damage....jerking,....ign,or gear prob's!"
"I have a 1973 18 hp 2 cycle e
"I have a 1973 18 hp 2 cycle evinrude Model is 18304A! I need complete bottom end of engine the main shaft which the prop goes on and all the gears etc. that go on the insde of the bottom end, like foward gear, reverse gear, dog clutch etc. the whole assemply please ! Does anyone have it?? Thanks Mack"
"(Jumping Out Of Gear - Ma
"(Jumping Out Of Gear - Manual Type)
(J. Reeves)
This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".
Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.
When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.
The lobes of the dog and gears are precisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are precisely machined with sharp angles!
Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those precisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.
Some boaters with manual shift engines have the mistaken belief that shifting slowly is taking it easy on all of the shifting components..... Wrong! Shifting slowly allows those precisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
