Our motor was in the shop and repaired for a broken driveshaft last fall, but on putting it back to use, the water circulation is not right. The motor does not discharge water and the engine rapidly gets hot at idle. Where do we begin troubleshooting this issue? We have replaced two bad gaskets on the impeller, and the impeller appears to be functioning. We do not know how to determine if the water jacket is continuous going up thru the motor and suspect that somewhere in the process of taking the motor off the top that the problem lies.
