Greetings, I'm having some difficulty in understanding the function of the idle stop screw. The part number is 304753 and it is threaded into the throttle control gear with a spring. It's a nylon screw with a metal core. If it is to simply keep the throttle from closing past idle, I would understand completely. However when it is set, wouldn't it keep the throttle handle and linkage from moving to the stop position?
The motor is not running and is under restoration, so I can't test the functionality of this gizmo. Just thought I'd throw this question out there for comments. Thank you in advance for your responses.
