Yes, there is lube in the lower unit. As it turns out, the individual pulled it over with lube in the cylinders several times. It did finally loosen up, and surprisingly, started and ran quite well. It's running a little warm as he wasn't able to hold his hand under the water stream for five seconds. And even though it started and ran, I can't help but feel that the coils wouldn't need to be looked at. I didn't know about that shock being inside the lower unit. I thought the only shock absorber was the rubber one on the exterior, If I'm thinking of the right motor.
