Sorry about the posting this in the wrong place the first time...
I just recently got a QD16 as well and despite assurances from the previous owner it has been giving me some grief. It starts after just a couple of pulls but takes forever to get to the point where I can shut the choke off and then what seems to be WOT is at some odd halfway point on the range of the throttle. It also will do the sort of clunk-and-miss thing for a while but generally only in neutral.
The other issue is putting it into gear. I move the lever into the proper position but often times in doesn't always engage the prop right away and then does so with a clunk. If I turn the handle all the way back to SHIFT to shift it it will stall so I move it a bit off and then the shifter will move but not always engage.
I haven't replaced anything yet and was hoping to give it a once over myself before taking it to the mechanic. It certainly needs some love and I'm sensing that it's worth the effort based on what I've read here so far. The motor is in overall great shape.
Any warnings or obvious red flags before I break out the wrenches?
thanks
Ben
thanks
Ben
