Gillbilly72
Hello all...I recently purchased a 1955 Evinrude Fleetwin 7.5HP #7518 and original Evinrude 4 gallon dual hose tank. I rebuilt the carb and entire ignition system, replaced the gas and oil and barrel tested it. It started right up but ran rough so still frustrated, I took it to the lake to test it out and dial it in a bit more.
I started it at the lake and the motor ran flawlessly for a bit like it had just came off the showroom floor but I noticed that I hadn't hooked up the fuel line at the motor and it was simply running on fuel in the glass carb fuel bow so I shut it off and hooked up the fuel line. Primed the tank and started it again. It would start up, idle and run at low speed but not as well and would not accelerate up to higher speeds even with the throttle handle cranked to fast . I attempted to find the correct settings on the carb adjustments to smooth it out but had no success.
My question is- Could there be an issue with the tank, the hoses or the quick connector at the motor that would cause it to run "rich" or rough while being hooked up to the tank? There doesn't appear to be any leaks at the tank and holds pressure because when I release the pressure there is a long hiss when the cap is turned. The hoses are decent with clamps and the connector works other than fuel that seeps out of the tip of male connector at the motor after being disconnected. It seems like it's getting to much fuel even with both carb needle adjustments lightly seated. Or is it the opposite and drawing air from somewhere? Thanks.
