Hey guys, I need some help locating a starter or possibly a replacement starter for my 1955 Evinrude 25hp Big Twin.
(Original part number 277311)
I traded some work for the motor from a customer that said the motor had only been used on a one week fishing trip his dad and uncle took every year, then the motor was drained and put in a shop. Honestly I didn’t believe him until I took the hood off and it looks like the day it left the factory, clean as a whistle. After not being started in over 10 years it has exactly 90psi on both cylinders. I’m hoping that after running it maybe the compression will improve some. I’ve dug through the motor inspecting seals and the only once in need of replacement have been in the foot but besides that the water pump and everything else is in pristine shape.
the only thing missing is the starter. I have all the parts diagrams for this motor but I cannot find a starter anywhere. Do you guys have any clue if there is a starter that might work on this motor? I’ve seen some reproduction ones that claim to work on Johnson/Evinrude dating back to 1966 but nothing stating that it will fit my engine specifically.
I have taken allot of measurements to see if maybe I could find a starter that fits and will reach the correct height once engaged but I haven’t laid my hands an another starter to measure yet.
I have dug through several motor graveyards and the closest model I have found to mine is a 1969 33hp.
Here are the measurements I have taken. (Measurements are exact done with calipers)
- distance from the top of the gear teeth on the gear ring to the face plate where the starter mounts; 2.884”
- diameter of the starter mount face plate; 2.750”
- mount bolt hole spacing; 2.750”
any help would be greatly appreciated because starting this ting this bad boy by hand is going to tear my rotator cuff!
