Hi all, I'm I've recently purchased a a 14' lone star boat and it came with a 5.5hp johnson. I believe it to be a '55? I've not figured out how to find that out for sure yet. Any how, he'd not started it for at least 5 years and it sat outside on the back of the boat during that time! I pulled the motor and put it on a stand and tested for spark. It had great spark!! I cleaned the carb , pit the motor down in a tub of water, well below the pick up screen and gave her a yank. It fired first pull after sitting 5 yrs!! I was stoked, until I seen it wasn't pumping water. I've purchased a new impeller and am currently trying to find the o-ring and cork gasket needed in there as well but I'm having trouble locally with that, any suggestions? I'd like to change all the lower gaskets, so I was thinking there may be a complete lower gasket kit available? What type and weight of oil do I need to put in the gear case?
My local marina told me to use a 50:1 fuel mix in it but I read another post that said a 24:1 mix is needed instead. Any help with these issues would be much appreciated. I'm new to boating , as this is my first and am trying to get this going to take my boys fishing yet this fall. Thanks ,Rick
