1954 johnsonseahorse 10
sunliner
Oooops.I blew it. I forgot to
Oooops.I blew it. I forgot to count the # of turns in before removing the idle jet soooo can you tell me the # of turns out the idle jet should be to sart with?
"Later models are 1½ turns but
"Later models are 1½ turns but IIRC older ones are less possibly ¾, maybe 1.
Try it at ¾
Set the high speed one, if its adjustable, first then set the idle one at the lowest posible speed.
Joe Reeves adjustment procedures:
<blockquote>(Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. </blockquote>"
need torque specs on my 1954 j
need torque specs on my 1954 johnson 10hp QD-15.. for the following 1. Head bolts? and 2. top nut that hold the flywheel over the magneto... can anyone help me out... thanks
"Old 50's model 10hp johns
"Old 50's model 10hp johnson dual line gas. engine starts fine, runs a few seconds and goes dead. Bowl is full bulb is hard.I took carb apart, it is clean looks new inside and out! I don't know how this air pressure tank works, but I think that could be problem? Any Ideas anybody???"
"If it has a pressure tank &#4
"If it has a pressure tank (which a 50's 10 Johnson would have unless converted), there should be no bulb. There should be a plunger on the tank. It does sound like it's starving for fuel. If it is a pressure tank, it will have 2 lines going from the tank to the engine, one so the engine can pump air into the tank, the other for the fuel to travel to the carb. You need to make sure the cap is screwed tight so air doesn't leak out the top or there won't be any pressure to push the gas back to the carb.
Do you have a model number for the motor?
For future reference, you should create a new thread when you have a new question.
Good luck."
