1954 johnson 3 hp jw-10
clayvogt
hello when setting the points should i set the gap when the crank key is centered on the point spreader or when the letter o in the word top on lob roller is centered on the point spreader thank you clay
(Point Setting Of Magneto Models)
(J. Reeves)
Set the points as follows. Have the flywheel key aligned with the fiber rubbing portion of the ignition points. Adjust the gap so that a .020 gauge will pass thru but a .022 will not. Should there be any question of the points being dirty (touching the contact with your finger would cause them to be dirty), clean them with a small brush and acetone or lacquer thinner.
NOTE: Should the operating cam have a small portion on it with the word "SET" imprinted, align this portion with the fiber rubbing portion instead of the flywheel key.
Why not use the timing marks on the flywheel and the magplate ????----------Set them right on the money using an ohmeter.
