1954 evinrude flywheel removal
I want to replace the coils they are cracked the motor runs fine flywheel seems to be stuck don't want to break it looking for suggestions on how to take it off
search thread: stuck flywheel
I got some great help, the thread talks about all the tricks you'll ever need.
Worked for me.
I just replaced the coils but they seem to rub on the flywheel when I pull to start . It rubs a little and brings the throttle to off. Will this be ok ?
No , the coils will need to be adjusted properly !!!-----They can not stick out past the " boss " that they are mounted on.
(Magneto & Driver Coil Alignment)
(J. Reeves)
To align the coils properly, have the metal vertical portion of the coil yokes aligned with the inside edge of the bevel that exists on the top portion of the aluminum seat upon which the coils sit. This creates the proper distance between the coils and the flywheel magnets. Faulty alignment creats friction and the yokes of the coils heat up, turn blue and expand.
