misslemike
"My 1953 Johnson 5 HP Seahorse
"My 1953 Johnson 5 HP Seahorse starts up. Then it seems to run ok. About 3 minutes later out on the lake it starts to backfire and stalls. After restarting, it begins to sputter again and as I play with the mixture and the carb lever underneath it seems to come back to life, but only for a couple of minutes more when it does it again and stalls. After priming it again and waiting a few seconds it seems to start up and as it sputters I try to adjust for the 100th time and it might run nice for only a few minutes. I am a newbie here but I wonder if gas is getting to it because it sure leaks a little from somewhere underneath. But then, today, It runs like a charm for about 30 minutes, but then back to the sputter, backfire and stall. The guy I bought this from only says that I need to learn how to adjust it properly. But when I get it adjusted right and it runs well, it will only be a few minutes when this happens again. I cant believe it is just adjustments anymore. Any help please. Thanks"
