I have been trying to restore my 1950 Evinrude Fleetwin 4434 that I inherited from my grandfather. I used this motor all the time when I was younger on a 12' v-bottom boat. It would move that boat along at a decent speed. The motor had sat in storage for about 12 years after my grandfather passed. I finally have the time to mess with it and would love to have it working like it did back then. When I first tried to start it there was no spark whatsoever so I tore into it to check the coils and points and noticed that the coils appeared to be melting away, they epoxy or whatever they are incased in had run down the sides all over the place. So I decided I was going to pull it all apart and replace anything that looked worn out or damaged. I ordered the service manual, found a new water pump impeller, seals for all the shafts and a carburetor rebuild kit for the tillotson MD 34b. When it came to the ignition I found that everything for the 1950 4434 were pretty much obsolete. So I got crafty and removed the stock coils from the laminates and replaced them with some Tecumseh coils I found online, I had to do some modifications but I got them to fit. Replaced the condensers with some condensers for a 70 chevelle and managed to find some new old stock breaker points. I got everything back together and to my surprise it started rite up. I have a little 14' v-bottom seanymph that I put it on and took it down to the river to give it a test spin. Got it in the water and started it up and went through the carb adjustment procedures outlined in the manual. It idles way better than it ever did when I was a kid but at WOT it just doesn't seem to have the power it once did. I brought it back home and have been tinkering with it for the past few days trying to find the issue with no luck.
Checked compression 80psi on both cylinders
Regular pump gas mixed 16:1 with Quicksilver Premium Marine 2-stroke oil
Points are gapped .20
Champion J4C plugs gapped at .30
Float level in the carb is adjusted 3/32 below rim of fuel bowl as instructed in the service manual
Checked the ability of the coils to jump a 1/4" air gap per manual instructions
And made sure the cam follower closes the butterfly when the armature base is in the stop position
I have triple checked everything and it all is as it should be as far as I can tell.
Do you think it might have something to do with the coils I used to replace the obsolete ones?
I was thinking I might try stepping up the heat range on the plugs to compensate for the coils, maybe they are not as powerful as the originals.
I have the j4c, j6c, j8c and j11c champion plugs but was concerned that stepping up the heat range could possibly burn a hole in the pistons.
Anyone have any thoughts or recommendations? Am I missing something obvious?
