"Hi.
This restoration proj
"Hi.
This restoration project starts and runs well at high speed. No amount of carb adjustment will get it to run lower than at the "Start" position. I finally borrowed a compression tester (the universal kind with the rubber tip) and I get only 50 psi in both cylinders after a couple of pulls. I'm told it should be closer to 80psi to run properly. I'm confident that the head is torqued adequately and gasgets are new. Am I looking at piston and/or ring replacement next? I also question the 50psi reading. Could the motor start and/run this good at high speed with compression that low? It's an old tester, and I'm wondering if it's bad.
Any input would be appreciated.
Thanks! Chuck"
"Hi.
Thanks! Chuck"
