1919 johnson fuel flow restriction
"fuel does not seem to be gett
"fuel does not seem to be getting to the spark plugs, i have to spray a fuel mixture to get it started. when running full throttle. i get a beep stating fuel flow restriction. if i give it a little gas in reverse or forward it cuts off, but if i go ahead and excellerate it runs. any ideas."
"you need to completely ck out
"you need to completely ck out your engine for starters,..spark,compression,fuel delivery.I would ck the primer.and oper of it...if u dont have a manual,i suggest u get one,its full of useful info and pix."
"if u are still on the VRO,..a
"if u are still on the VRO,..are u familiar w/all the tones....u may not be getting fuel restriction,..if u think u are,change all filters,ck the anti-siphon valve on fuel tank...if present,,chg primer bulb..."
