I have a 1970 18 fastwin that overheated. I replaced the waterpump (bizarre... the bushing in the center of the impeller separated from the impeller causing it to just sit there without pumping water. never seen that before) and now it pumps water like mad, but the powerhead still gets over 210 degrees! I took the t stat out and left the housing open to see if any water was being pumped. it barely pumped any water to it. could the heads be clogged? When it overheated, it got to (best guess) well over 250 degrees. maybe something melted under the powerhead and its causing a blockage? Ill pop the head off and have a look, but any suggestions?
