"The port engine in my 1962 Tr
"The port engine in my 1962 Trojan starts idles and rev's fine but it losses power under load.
The engines turn in opposite directions however the distributors turn in the same direction, This engine simply will not run when setup with the firing order that is called for in the book,these are flywheel forward engines, so because the distributors turn in the same direction, i used the same firing order. the engine fires right up! and idles nicely but has no power under load.
I have good compression and have been through every thing from intake and ignition to exhaust with no luck.
Is my problem still the firing order?"
