175 HP Evinrude Fitch 2003 will not idle
gcook
"For some reason it will not i
"For some reason it will not idle stalls at low rpm. runs fine soon as you give it throttel. Checked for water in fuel , none. Thought it might be a air leak in the fuel line. pumped bulb still staled? If anyone has any ideas?"
"this eng,must go on a laptop
"this eng,must go on a laptop computer,to properly diagnose,repair....one of the downfalls of owning a newer eng."
"As JW says, any really involv
"As JW says, any really involved troubleshooting requires a computer. You can still check the basics like spark plugs and fuel filters though. Might save you a trip to the dealer."
"If no codes/alarms, most like
"If no codes/alarms, most likely not much to get out from the computer.
Would suggest You hook up and test fuel pressure.
Might even be a spark plug problem.
If You are not familiar with the engine, leave it to a dealer that has the 'tools' and experience, no 'back yard' mechanic."
Thank you for the info. I talk
Thank you for the info. I talked to a dealer said spark plugs on this engine would only last 50-75 hours.had about 200 hr replaced plugs runs mint thanx
