Hi.I have a Johnson ficht 175Hp 1998.The problem is that I plug the engine on Evinrude Diagnostic Software(Evdiag 4.6) and when the engine is running I have an indication of orange FAULT OIL without any trouble code.When the engine stop's the indication is green OIL OK.I change oil lift pump,oil ingection with distribution manifold,I check one by one all the oil lines from the manifold and I have oil delivery,I check the oil return pressure regulator,but the problem still remains.I'm out of ideas.Any help will be useful.
When the engine is not running,on the EVdiag,in the testing section I haven't the ability to actuate the oil ingection,if this does matter.
