fvsaopedro
We have a 16V92NA in our ex Gulf style tuna boat. We have just had a couple of heads done up and replaced liners. I set the rack up as per the book - or so I thought, adjusting 4R down until you can feel it against the stop lever - this results in the injector rack being nearly all the way in. I did the same with the other 3 heads and then disconected the tubes and set the other injectors off the 1st one for each head.The governor and linkages are a bit flogged out so its a bit tricky to get right. On start up she went to full fuel and would not stop (all though revs did decrease) *with the stop lever. I had to use the air shut-downs to get her to stop. I did not set it up myself last time alltough*the racks seemed a lot further in than before. Have I done it right?
Cheers Chris
Cheers Chris
