I had the boat out on Monday and after about 2 hours of running perfectly it just shut off while we were running. I touched the coil and it about burned me. So I figure the coil went bad. I installed a Mallory electronic ignition about a month ago and have run the boat twice, counting Monday. I called Mallory on Tuesday and they recommend using their coil that puts out 1.4 ohms. They also said it has an internal resistor. I noticed in my manual that the wire going to the positive side of the coil is a resistance wire. Is it ok to have a coil with an internal resistor and a resistance wire? The reason I ask is because I can get a replacement coil from Napa that does not have an internal resistor. The one from Napa also puts out 1.4 ohms.
