I have a 2000 model 15hp merc 2 stroke. The engine had water pump failure and over heated pretty good. I replaced the water pump - ( some fins were missing from the old one) put in in the water and it would pee at idle, but once I raised rpm's would stop peeing ... so I removed the pump and installed an OEM pump on it, I removed the rear cooling cover for inspection and replaced gasket, I removed and replaced the side - double plate exhaust/cooling cover and gaskets for inspection, I blew air the best I could to dislodge any debris. Compression test on both cylinders is 112 ...... put it back in water and same problem... idles fine and pee's water like a race horse .... once I start to raise rpm's it stops peeing and blows steam .... let it idle , engine cools to 120 degrees .... I have had the lower unit off multiple times to make sure copper tube and all is lined up. With the thermostat out - it wont pee water at all .... which is weird to me.
I am just wondering if when it over heated it did something in the engine to make the exhaust blow into the water jacket somewhere when you raise rpm's .... this engine does not appear to have a head gasket.
Thanks for any help
Thanks for any help
