PontoonSam
I'm hoping someone can give me a good guess as to what this problem is so I know whether to take the engine to a guy or try wrenching on it. Here's what it is doing:
Take the boat to the lake today, engine fires right up and we run out the a nearby spot to fish. Medium throttle, coast to the spot, reverse for brakes. Everything working good. Run to a couple other spots, same story. Hit full throttle a couple times out and back without issue. Gas is reasonably new... say two weeks old.
Then I run back to the dock, try to use reverse to back away from the dock. As soon as I shift into R the engine dies. Starts on the first try, R = engine dies. At this point I decide to go forward to leave the dock area. I'm able to idle forward fine, revs a bit as I throttle up but the rest of the throttle movement does nothing. So I have no reverse at all, and only a bit of forward power.
Thoughts? I know I didn't hit anything between the last spot and the dock. Engine is a 1996 15EL. Model No: 1015312SD
Thanks!
Thanks!
