15hp 1980 evenrude driveshaft
601
I cant get the driveshaft out
I cant get the driveshaft out of the head.I took off the lower unit and instead of the driveshaft staying in the lower unit it stayed in the head and won't come out.How is it connected to the head? HELP!! PLEASE!!
"Then Your next job will be to
"Then Your next job will be to take off the power head, put the shaft in a vice up-side down (PH down), spray with WD-40/PB blaster etc and then after some time try to knock the power head off the shaft.
PS: Don' drop the powerhead on the floor when it comes off."
I've had the head upside d
I've had the head upside down for a week soaking in kroil no luck yet.Thanks
"I usually grab a non bearing
"I usually grab a non bearing surface of the driveshaft with a good pair of vice grips, then slam the top portion of the vice grips with the biggest hammer I can find. Take care not to bend the driveshaft."
I made a puller from a pair of
I made a puller from a pair of vice grips 3/8" rod and a 3-4 bls.weight to side up and down it.Not working yet.I've yanked the s--t out of it.I can't beleave it hasn't came out.I was wondering if there was a nut - bolt or something holding it? I was thinking of useing a hammer drill or hilti on the end of the shaft and vibrate the hell out of it?
There is no BOLT OR NUT HOLDIN
There is no BOLT OR NUT HOLDING IT just rust because of neglect.
"THANKS,This was given to me.I
"THANKS,This was given to me.I just don't know if I should put any money into it?It runs?"
