151 temp and rpm
L
laddie71
Guest
my max rpm is about 4400 and t
my max rpm is about 4400 and the temp is usually 190-200 and 180 at idle. What is a normal full speed temp and what is a safe max rpm to cruise at?
"The temp is correct. The maxi
"The temp is correct. The maximum RPM range should be 4800-5500. I was normally cruising at 4500-4900 with my AQ140A, but went over a few times with no problems whatsoever."
"That sounds good. I had a mec
"That sounds good. I had a mechanic work on my engine and he told me never to run over 3500 and the other day as I was steaming along, I thought, this is pretty slow. Thanks again"
"I find your mechanic's re
"I find your mechanic's recommendation very strange, unless he has never worked before on VP 4 cylinder engines. Also, if your engine is well tuned, your maximum RPM indicate that you are a minimum of 2" pitch overpropped. What prop do you have installed now?"
