150hp mercury power trim help
merc150
No smart a## remarks OK..... I
No smart a## remarks OK..... If u cant help with out being an a##hole don't post.... My trim will go down but wont go up.I checked the voltage and its getting plenty and it don't make any noise when I try raising it up.Any help would be nice..
"If it didnt make a noise when
"If it didnt make a noise when you hit the up button,it sounds like your solinoid is gone ,you can short across the solinoid which should lift your motor,while you are in that area check your fluid levels as well ."
"I got it up..Thanks a lot man
"I got it up..Thanks a lot man.
