150h Johnson outboard
robert3966
"1993 Johnson outboard Model #
"1993 Johnson outboard Model #VJ150elatr Did compression test on all 6 cylanders. 4 showed 80psi and 2 showed 75psi. Shot oil in cylanders and re-did test, with same results. Do these numbers sound low, or is it normal?? Thanks for any help."
"i would say,your eng has alot
"i would say,your eng has alot of hrs...
try doing a de-carb on it 2-3 times and see if comp comes up."
