Hi Guys.
Well today I decided to start my 09 150hp Optimax after it has been sitting for 6 or so months.
I changed fuel, filters and added treatment.
I backed the boat into my small dam and lowered the tilt to put the engine into correct depth then hit the starter.
After the usual couple of cycles to built air pressure the engine fired straight up then almost immediately began knocking then stopped dead..
I tried to restart it but couldn't.
Then I manually wound the engine over by turning the flywheel and it seemed ok..Again I hit the starter and it fired but stoped dead again.
I then noticed fresh oil running out of the exhaust so alarm bells went off..I pulled all the plugs out and found no 6 cyl had no compression..
So with a heavy heart I began tearing the engine down from the intake side and once I removed the reed plate I found some lovely big chunks of alloy and steel..I am guessing them to be a gudgeon pin and bits of piston.
So my questions to you guys is,
What do you thing would cause such a failure to occur ? It cant be lack of oil because the thing is dripping wet inside and in the bad cyl.
How do I split the crankcase? Do I need to remove the powerhead or can I split the case insitu? I have taken all the bolts visible out but it seems to be still attached strongly..
Thanks for reading and in advance for your help.
