150 Merc Outboard Compression
ddonaghue
"Hi,
I have a 1984 merc 150
"Hi,
I have a 1984 merc 150 outboard, V-6. The compression in all 6 cylinders is 120, which is good that they are all even...but what should the compression ideally be - 120 or more? What is the compression when new or rebuilt?
Thanks, dan"
"I've been told that if al
"I've been told that if all are within 10% of each other, then that good. However it doesn't answer your question."
I've never seen that data
I've never seen that data published but 120 in all cylinders is excellent. My old 1983 150 ran 113-115 psi.
"Maybe it wasn't as high a
"Maybe it wasn't as high as 10% but if there within a certain range of each other, than i have been told that it is ok. I really don't know, is that still ok IBNFISHN?"
"On the V6 Mercs anything over
"On the V6 Mercs anything over 100 psi and all within 10-15 psi of each other is fine.
120 psi was probably about what it was when it rolled off the production line at Merc, so you should be well pleased with that..."
