cricket4462
My 1995 150 Mariner outboard will run great start great every time since I bought it in 1995. Although I have replaced spark plugs throughout the years it has always ran great. I started having an issue with it as of late. Here is the problem....after running it for seems like a 20 minutes or 30 minutes it will all of the sudden bog down and almost stall out at high speed. Then it will be missing terribly. I then will try to get back on plane and it trys too but stalls out again while trying.
I do notice after letting it sit for a half hour or so it will run fine again. Seems like this is an issue with something miss firing after heating up or after running for a longer period of time at higher speed. Could it be a bad ballast resistor or ignition coil or control module?
Please help with some information on what it might be or what I can try in fixing this.
Thank you
Thank you
