Wantintofish
It starts and idles fine revs fine until under load so far I have checked compression (148-153) cleaned and replaced fuel system disassembled and cleaned carbs new stator and trigger and plugs no change. If I put a passenger up front it will plane off eventually but full throttle and trim it will only reach 4200 rpms. Without the weight up front it will just struggle at 1800 rpms. When I test at home I have fire on all 6 could it still not be firing all 6 on high after replacing the stator? Bad switchbox? Idle stabilizer? Help!
