zackfactor
ok here it goes i got 2 questi
ok here it goes i got 2 questions this time. i bought a mako with a pair of 1994 150 loopers on it a while back. motors got 246 hours on them and havent been ran since 2001. after much headache i got the carbs and the vst cleaned. while running the stbd motor the other day after about 10 minutes i notices a distinct knocking sound. immediately i shut the motor down and pulled the plugs. they looked fine. so i dug deeper and pulled the cover off the flywheel. i could not find a loose rod bearing by turning the motor by hand and it has 120lbs on each cylinder. however i can move the whole crank back and forth ever so slightly and hear the same knockso i am assuming that a main bearing went bad. my question is what could cause this on a motor with so few housr on it. the other motor is fine. btw the oil injection has been unhooked since new on both engines and gas was mixed at 50:1 at time of failure.
my second question is this. i was given a 95 150 evinrude that has around 1100 hours on it. this motor also has 120lbs on all cylinders. will i notice a differenve in performance between the 2?
thanks in advance
thanks in advance
