"Mr. Lamb, this is probably ri
"Mr. Lamb, this is probably right up your alley! Have 94 Merc 150 BK Max. Heading in offshore, motor ran out of fuel?? No fuel in the clear filter I had installed, and bulb was "HARD". Couldn't pump fuel in. Got it home, replaced fuel lines, fuel water sep. and inline filter, got the motor to run on the muffs. But, bottom two cyl. not firing! Got 125 PSI in each cyl. - Could fuel pump, not be sending enough pressure to the bottom carb. I can put my hand over each carb, and I get lots of fuel and the engine revs up? Quite confused. Help anyone!!!!"
