150 Blueband no acceleration
"Hi all,
My name is Kr
"Hi all,
My name is Kris and have a last model 150hp Blueband motor with a dizzy (78-79?).
My problem is it won`t accellerate from idle. It goes to, stumbles, revs drop and would probably stall if i keep it this way so i just back off the control so it idles still in gear .
History;
I bought this motor to replace my old 140 Chrysler, the Merc has been rebuilt by the previous owner with about 15hrs on it.
This is the first time out in it.
He suggested i still run 25:1 mix for the next 5hrs or so, so i do with 98 octane PULP.
Motor is still tight but haven`t done compression test yet but was assured all at least 150psi.
Had to rewire some corroded wires.
19 pitch prop.
15 foot runabout.
It idles great and starts well.
New water pump.
New NGK BUH8 plugs.
I have removed the fuel pump but everything looked good but need to buy a rebuild kit. This pump mounts on a 3 pointed stand/bracket behind the starter solenoid, has one hose that connects to the underside of the pump to the very lower part of the transfer plate (no. 6 cyl) and another hose to the side of no. 5 cyl.
Can anyone help me out with some ideas on where to start?
Sorry for such a long post but wanted to give as much ifo as i can. Kris"
"Kris, It is likely that your
"Kris, It is likely that your carbs are set too lean to accelerate. You should also check to make sure the spark plugs are the correct ones, since I suspect you should have BUHW plugs. First set the carbs to 1.5 turns open from lightly seated. If acceleration is still bad, the open the top carb screw 1/8 turn and try to accelerate. If it accelerates OK, your done. If not try the mid carb 1/8 turn open. Try to accelerate again. If OK, your done, if not repeat with bottom carb. You will want to set them as lean as you can, with good acceleration. Do you think the rebuilder has set the timing on the motor? Here is a link and sync procedure for that motor from an inline expert named Clams Canino. BTW, I have a '77 1500 Merc. I do not agree with Clams on the carb settings, which is why I recommend 1.5 turns.
Manual specs are different for each but this is close enough to get them all REAL close. This assumes nothing is broken or "wrong" with it. This also assumes that the timing pointer is properly adjusted (if adjustable) to accurately read TDC of the #1 piston.
This basic procedure will work for all the 2/3/4/6 cylinder inlines from 1960 to 1988. It's not for the newer 3 and 4 cylinder loopers.
Engine off
Disconnect throttle cable
Pull throttle arm to full throttle and verify carbs open fully. Adjust main throttle stop so that the carbs are JUST hitting thier own little throttle stops. The idea here is that you want the screw stop and NOT the carbs acting as the "final stop" for your throttle lever.
Return the throttle to idle, carbs should be closed. Set all idle screws to 2 1/4 turns out from lightly seated.
Remove all plugs except #1, hook a timing light to #1. Then follow the narritive.
When the throttle is in the idle position the carbs should be fully closed and the ignition retarded. It the amount of retardation that determines your idle speed and is set later with the idle stop screw.
Timing Event One - throttle pickup.
As the throttle is advanced, the spark timing advances toward TDC and then to before TDC. As the timing is just passing TDC the 1st (minor)throttle pickup should hit and start to open the carbs. Use the timing light. Adjust the tang or trigger screw to make this a reality. All of them are speced different, but if the 1st pickup hits at 3-4 degrees BTDC advance - you win. Use the timing light with a friend cranking it to complete this setting.
Timing Event Two - max advance.
As you continue to advance the throttle the timing will advance while the carbs slowly open a bit more. The next adjustment is max advance, this is the point where the distibutor (or trigger) can advance no more. Set the max-advance stop to 21 degrees for "direct charge" inlines and 34 degrees for the older crossflows. Use the light, - err to the side of caution.
Right after max advance, further throttle motion should cause the second throttle pickup to hit and open the carbs to full. You already set that -now verify it.
Leave the throttle cable disconnected and go to the water. Leave the boat strapped to the trailer and back it in so it's deep enought to run. Have a friend crank it while you operate the choke and throttle. Warm it up at 1500 rpms's.
When "warm" adjust the idle stop screw for about 800 rpm and then ajust your idle needle(s) in (one at a time) till the motor stumbles. Quickly backing it out 1/2 turn from "stumble" will usually save it from needing a re-start. Do that for all the idle screws. Re-set idle stop for 800.
Now have your friend put it in gear (make SURE you are on the transom NOT in the water) and reset your idle stop for as low as you can get it. 500-600rpm is great if your old reeds will let it idle that low in gear. Now, re-adjust the idle screws, in to stumble, then 1/2 turn out. When you've gone back and forth with that a few times and have it "perfect" - adjust each one out 1/4 turn.
Reset the idle stop so that it's about 700-800 out of gear and 500-600 in gear. Sometimes bad reeds won't let you get that low, you've GOT to get it under 1000 in neutral (worst case) to avoid beating up your lower unit when you shift into gear, even 1000 is "bad" but like I said "worst case".
Now adjust (and hook up)the throttle cable so that with the shifter in neutral, there is light to moderate pressure holding the throttle arm against the idle stop.
Take the boat off the trailer and go out in the water. Try the hole shot. If it falls on it's face try adjusting the idle screws out 1/4 turn at a time (all of them together) till you can get a hole shot. You can kind of do this on the trailer at the ramp, but it's not really safe for you, the boat, or the tow vehicle.
You're done.
-W"
"Thanks Chris1956 greatly appr
"Thanks Chris1956 greatly appreciate the time you took to write all that!!!!
Yes you are correct, i do have BUHW plugs.
I have posted more details on the problems i have found so far on my other post (compression specs).
Once i get it back together, will print this out and go to the lake to try this with a mate.
Thanks for the great advice!!!
Thanks again,
Kris"
