15 johnson
hillbilly
were is the pee hole on a 15 j
were is the pee hole on a 15 johnson i cant seem to find it. it should be right there but am i over lookin it. its about a 1975 i think. it ran find but it was peeing like most other motors
I dont think you will find one
I dont think you will find one on a '75 model. It first appeared on the '77 models where it exits from the bottom cover stb'd side rear corner.
Check the model number to determine the exact year
see thats the prob it dont hav
see thats the prob it dont have one i lookd it over and it must got ripd off or somthing over the years because i cant find it. so how would the motor cool its self then?
"the pee hose,..is just an ind
"the pee hose,..is just an indicator..u would have the same pump,as,is used on all 9.9 & 15's."
"As JWBMarine says the pee hol
"As JWBMarine says the pee hole is only an indicator. It tells you that the the pump is pumping and can often lull you into a false sense of security about the cooling system as a whole or cause unnecessary concern when it gets blocked.
The main cooling water flow is discharged into the leg and exits underwater with the exhaust gases. Normally though you would expect to see some water, just as a spray or a few droplets, coming out of the exhaust relief port at the top of the leg.
There is an item on the engine faqs board about adding a tell tale to engines that do not have one if you are that concerned."
"when its running there is som
"when its running there is some water that comes outa the exaust.
and this brings me to my next thing well before i knew that it didnt have a pee hole we hookd muffs up to it just to see if we could blow it out. well when we were i see a lota water come outa here. well i know i have to replace it but what does it do and whats it calld.
url]
"The bit with the two bolts go
"The bit with the two bolts going through it is the lower mounting bracket. Below it you can see the shift rod passing from the bottom of the swivel bracket assembly into the bottom part of the exhaust housing assembly. There are no seals around it at that point so yes you'll get water coming out of there but there should be a gromet down there. Perhaps that's missing so you get more water comming out that you would otherwise
Looks like IMG tags don't work on this forum! You'll have to read "Help" to find out how to include pictures or make them attachments!
hillbilly engine"">
Taken me a while to figure that one out"
in that picture under the to b
in that picture under the to bolts is a rubber washer that is broke. or is that the gromet?
and for the pics the way i did it it works on other fourms.
"Friend has one, and I see the
"Friend has one, and I see the pee coming out of the left side, under the metal- beneath the light motor cover. Probably in the middle of the left side, or 3/4.
Hope that helps."
[i]"a rubber washer that i
"a rubber washer that is broke. or is that the gromet?"
Yes i think that must be the remains of the grommet but I cant decide if it is vitally important. Maybe not. I think it will be a big job to replace it but something to be done next time you drop the lower unit to renew the pump impeller.
I know about how pictures are posted on other forums. This one works completely differently. Not so easy but there are lots of things you can do that you cant on the others.
The "shaft" you can se
The "shaft" you can see in that gap is just the gear shift rod. When you operate the gear shift you should see it move up and down.(Turn the prop slowly as you operate it because the clutch may not engage if you dont)
