15 Hp Mecury mtor wont start
pstodgell
I have a 15 HP Mercury Motor which wont start. The motor is 4 years old and we used it this spring on a 14' Zodiac boat. It travels in the basement of our motorhome. I put the motor on the boat, and tried to start it, but it will not go into gear and the propellor wont turn. I put WD40 into the piston but it hasnt helped yet. Any ideas on how to get it to go- it is cutting into my fishing time
...and tried to start it, but it will not go into gear and the propellor wont turn.
It only starts in neutral. Does it spark? How about trying a new spark plug? Have you been running the engine/carb dry when done w/it before storing it? If the engine did not fire when you shot a good dose of WD-40 in the plug hole and replaced the plug then look for a spark issue first. Check the trigger coil and stator. If the spark is VERY GOOD then the carb may need cleaning. Some fellas disagree but the carb can be soaked w/o disassembly. It's a very simple procedure. Let me know if you want to try it.
