" Approx 1994 Johnson
Model
Model J15RENM
Ser# 03063516
Can anyone tell me the year of this motor, also the motor is now not starting after changing the recoil spring. I've changed the gas, gas line, bulb, spark plugs checked the screen in the gas line. Its appears the motor when choked only goes for a short time. I have adjusted the needle valve to the carb as recommended (snug in and then 1 full turn out) but I cant get the motor running. Tonight I will try spraying gas in the plugs and see if I can get this motor to start, but is there anything else I can try? I will also check for a spark? HELP !! "
Model
Model J15RENM
Ser# 03063516
