I'm testing my '92 Johnson outboard and was just wondering what kind of DC voltage should I be getting before or after the coil? I am an electrician, so I have a very good digital meter that I set to tell me the min/max voltage as i pulled the rope. The most I ever got was 1.267 VDC.
Also my engine is recirculating water but seems to be overheating as the coils were a little melted to the block. And it melted the rubber wire protector on the wires from the ignition system under the flywheel to the coils. Should i replace the water pump or just try to clean it?
