Somebody still does know how VRO works.if ur going to buy something that old investigate if a piston rebuilt has be done, if not anticipate of doing it. those engines run hot due to vro causing oil starvation resulting is worn out seals rings & cylinders to get out of specs.
A 15HP from the 80's or 90's will be just fine. It will be a pre-mix only engine, but that's fine. These are very reliable little motors with just a little bit of maintenance. I have a '79 9.9, which is nearly identical to a 15HP, and it runs like a top. I had to chase some cooling issues, but once that was solved it has been rock solid reliable.I'm going to be buying a johnson or evinrude 15 hp outboard motor either 80s or 90s probably. Is there any years I should stay away from?
The main problem with them is the ignition system did not have a strong spark. Thats why a little hotter NGK plugs work well in them. There was also problems with the carbs not being very good. And the magneto rings were poorly machined. Because of the weak spark and bad carb you got carbon build up. Not to mention gearcase issues with leaking.So what causes those exhaust relief holes to plug? I may have the answer, but for now I am listening. Have had lots of those very first 9.9 and 15's. The only basic difference that means anything is the carb.
Fishhawk-----Where did you get the idea that a 15 HP would be running with a VRO system ???
