15 hp johnson 4 stroke1996
welovet
"motor coughs and spits, then
"motor coughs and spits, then quits after warming up. Runs perfect for first 10 min. Let it cool down and runs good for short time again, Coil, Power pack, plugs ? Any comments"
"Check for spark when it shuts
"Check for spark when it shuts down...is it overheating??? Tell tale pumping water???....if it has spark, try pumping the primer bulb to check for fuel starvation problem"
"not overheating, water pumps
"not overheating, water pumps great. motor will start right away upon quiting but problem returns. Happens when motor is warm"
"When did You last change impe
"When did You last change impeller on that engine?
By own experience that engine needs a new impeller every second year, and at the same time check the thermostat.
Your first posting however indicates something between timing and lean running. Quite honestly on a lot of them I have had to change Power-Pack, but they were in general totally dead! Another problem was a sticking plunger on the fuel pump which sometimes gave a similar effect. Try put Your fuel line from tank straight at the carb, bypassing the pump and use the primer bulb as pump."
