Hoping someone will know the answer (for sure) to this one before I roll the dice. I have a 2007 9.9 High Thrust (kicker) which now has 4 high hour years on it. Still runs like new doesn't use oil but starting to look ahead to rebuilding it. I don't like the new model 9.9 (stroked 8hp) as it doesn't have the pushing power and the motor mounts are so soft that the engine vibrates around more than it should. My other option involves this; buying a new 15 HP (4 stroke) short shaft, removing the complete powerhead and dropping it onto my 9.9 high thrust leg. Thus creating a 15hp high thrust kicker. I know the 9.9 is a de-tuned 15 so it should work. I was told to check the part numbers from the driveshafts of the new 2012 15 hp long shaft and see if it is the same as the part number for my engines driveshaft. If so it should work unless there is something else we aren't aware of. Anyone know the answer for sure?
